Driveshaft worn out?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76chevy, Jul 21, 2002.
  1. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    I am getting a lound bang when putting the TH350/203 in reverse so I changed a U-joint that had just a hint of slop.
    I didn't fix the problem so I'm thinking it is my drive shaft. The slip yoke and drive shaft can be moved up and down where they meet. I took it a part but I couldn't tell if the teeth on the drive shaft were worn or not and I couldn't see much on the yoke but there is a pretty good amount of movement.
    If that is my problem ,Is the drive shaft shot? How much for a new yoke and what would it cost to have the splines replaced on the driveshaft?
  2. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Youve got to take the driveshaft apart at the weld and discard the whole slip joint and buy a bew slip joint and reweld it to the tube.Not sure on the price to have it done but i was quated 150.00 for just the yoke and slip shaft....
  3. 76chevy
    Aug 16, 2000
    246
    Utah
    Wholy crap that is a lot. I' check around here and see what prices I can get on a rebuild along with having a driveline shop look at it.
    Thanks.
  4. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Is your shaft stock? You might be able to just go to a junkyard and find a driveshaft with the yoke still on it for cheap.
  5. Calclips
    Apr 4, 2001
    1,005
    WOW!!!! I just looked at the pictures of your truck, and that thing is nice... good lookin' truck man!
  6. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    The first thing that comes to mind is the ring and pinion. I have gotten the noise you described from my truck before I changed the rear end. It was wore out and there was alot of slop in the gears, so you would get this noise when putting the truck into gear. Just a thought, it might be something else you want to check out.
  7. 76chevy
    Aug 16, 2000
    246
    Utah
    Thanks for the compliment. The truck is a little more beat up now. I managed to scratch the passenger side 4 days after I finished it.
    I do have a stock drive shaft. Looking in a junk yard is a good idea. Thanks.
