driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bushmaster, Mar 25, 2004.
  1. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    dont know if im going with 208 or 205 yet wondering about rear shaft blazer 4"lift d60 stock shaft or cv shaft if cv shaft is better than who do you recomend? im going to be doing alot of towing on the highway
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It is hard to go wrong with Jesse at HAD (High Angle Driveline).
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Call Jesse....he can set you up! /forums/images/graemlins/peace.gif
  4. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    I had the same question before; the opinion was to run the simplest shaft (non-CV) if it was acceptable for the angles and speeds.
    Less parts=more gooder.
  5. bushmaster
    Jun 1, 2003
    146
    ct
    is there any disadvantages in running a beefy cv rear shaft slipyoke 208 style
  6. bushmaster
    Jun 1, 2003
    146
    ct
    is there any disadvantages in running a beefy cv rear shaft slipyoke 208 style i need a shaft either way
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    There could be . Depending on your suspension setup you may reach a binding point. In my own case I have been out 5 trips now on my CV sahft and have had no problems. It wouldn't be a bad idea to call a good driveshaft man ( Matt already mentioned one /forums/images/graemlins/waytogo.gif) and give him some measurements and discuss some of the variables, and get some info for both shafts. /forums/images/graemlins/k5.gif
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I was going to go all fancy with a CV but the problem with the cadillac CV is that it isn't as strong as a 1350 u-joint. I am pretty sure though that Jess has a bigger CV available but it isn't cheap. I wound up and just had the machine shop that machined my motor build me a pair of shafts. The guy that built them told me that my angle wasn't severe enough to need a CV and that the 1350 u-joint is stronger. I went with a new 1350 slip yoke, 1 ton 1350 neapco u-joints at both ends, and 4" tubing.
    My angle isn't all that bad even with a 7" lift.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Jesse has a 1350 CV.
    What good is all the power in the world if your driveshaft is laying on the ground? /forums/images/graemlins/rolleyes.gif
    I waited far too long to call Jesse. Finally did last week and it's the best decision I've made as of yet.
    If a CV is not necessary to eliminate vibes, don't use one. I run a straight 1350 shaft in the rear but it's 52" long (shortbed truck). HAD is on it's way for the front, 1350 CV with 1410 up front. /forums/images/graemlins/thumb.gif
    Whatever you choose, don't use greasable u joints.
  10. husurddy
    husurddy 1/2 ton status
    Jul 28, 2001
    108
    Snow Hill, Maryland, go east \'till you hit water
    I just put on a new CV drive shaft tonight from Jesse at HAD (High Angle Driveline.) I have to say I was extremely happy with the quality. I haven't had a chance to wheel with it yet, but I'm sure it'll be the last thing I break. Money well spent in my opinion /forums/images/graemlins/woot.gif
