Driveshafts At Horrible Angle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88 jimmychanga, Jan 31, 2004.
  1. 88 jimmychanga
    88 jimmychanga Registered Member
    Dec 14, 2003
    56
    Dallas, Texas
    OK, suspension is really not my forte, probably how I got myself into this mess in the first place. My drive shafts are at horride angles, pretty severe. I don't take it into anything too serious b/c of that, but what's the fun in owning a Jimmy if you can't test it at 100%, right? Anyways, how do I go about getting the drive shaft straightened out? Lengthen the shafts? Any help will be appreciated. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    How bout wedge blocks?
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    You can get shims for the axels, drop the transfer case a little will give some for the rear. Might consider a rear shaft with a cardon joint(dual u-joints like the front shaft)
  4. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    every rig acts a bit different. with 6 inches of lift, you are going to have to make some type of driveline adjustment. do you have drive line vibration at this time - i would think so. although a bit pricey, i went with a cv driveshaft (as bablazer73 stated) and corrected the pinion angle. mine rides better than it did stock.
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I got my drive shafts lengthend and had a CV kit installed on the rear shaft at Sacramento Driveline Service.
    This might help Drive-Line Service
    Bill
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    yeah what he said ^ /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
  7. 88 jimmychanga
    Dec 14, 2003
    56
    Dallas, Texas
    I'll try to get some pics up of what I'm talking about. Thanks to all for the help.
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    If you havent dropped you t case yet, there should be some factory 1"(?) spacers on top of the frame rail, where the bolts for the tcase crossmember bolts up. If you have there are little shims, wedges, only a couple bucks that you can get that rotate the front of your diff up at the tcase and will help w/ the vibrations a bit. Probably have to end up w/ shaft lengthened.
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    and you thought you had shaft problems...
  10. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    dear god
  11. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    ive seen that pic before, but just noticed the clear tube on the right. Is that a fuel filter the line goes in to?! Least hes worried about gettin water in his diff when he goes off the trailer.
  12. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]That is a "must" need part for when he is trying to get it loaded back in the trailer as it starts to rain.. /forums/images/graemlins/whistling.gif
  13. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    A gas line filter wouldn't be wort a crap as a vent, would it?
