Driveshafts-Lifting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ragbagger, Jul 15, 2000.
  1. Ragbagger
    Ragbagger Newbie
    Jul 4, 2000
    4
    Salida CO
    Do I need to lenghten the drive shafts on our 77 Blazer with a 4 inch Lift? My son and I are doing this project and we are new to this. It has been a great experience for us.
  2. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    four inches- nope, no drive shaft mods required. you might want to lower the transfer case though, that will supposedly eliminate any vibes you might on a four inch lift. any higher lift and you would need new shafts.
    someone else should probably tell you about the t case lowering, i'll end up telling you something wrong and i dont want you to mess up your truck on account of my bad directions. [​IMG]
    just start a new thread about tcase lowering.
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    With a 4" lift you might need a new driveshaft, I did. It wasn't even close. It depends on the condition of your old shaft, the brand of springs, and the type of wheeling you do. Jim.
    BigJBear '80 GMC
    http://www.bigjbear.coloradok5.com
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Lowering the t-case has been covered quite a bit on this board. Do a search, you should find lots of info.
    BIGJ
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Its almost impossible to answer with confidence. Every truck is unique and different. Some trucks with a 2.5 inch lift will need a longer shaft while another of the same kind might be fine after a 4 inch lift. Just lift it and see. If there are splines sticking out of the slip yokes when you have your axles drooped down, its time for a trip to the driveshaft shop.
    '73 K5
    Chevy good...Ford bad
