Driveshafts Measurments
Discussion in 'The Garage' started by 84PolarBear, Jul 29, 2002.
  1. 84PolarBear
    84PolarBear Registered Member
    Feb 19, 2002
    86
    San Francisco
    I installed a 2 1/2 lift and now I need to lenghten the driveshaft on my K5. Where do I measure from and to for the measurement.
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    From the output shaft seal on your tcase or flange whichever you have, to the center of the u-joint on your pinion.
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Just wondering why do you need to lengthen the driveshaft?
  4. 84PolarBear
    Feb 19, 2002
    86
    San Francisco
    I don't know if I am going explaining it right, but the driveshaft will bind-up at the U-joint on the diff side. That with ranchos 5000 schocks. Right now I am using stock shocks, and the driveshaft will turn ok. Also the shaft that enters the transmission use to only have about a 1" showing know about 3". I am not sure if that is ok, and I think that lengthen the driveshaft is needed.
  5. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    you should be fine with 2.5 inch or a 4inch lift in back with a stock driveshaft..Iknow i am at least
    Blake
  6. 84PolarBear
    Feb 19, 2002
    86
    San Francisco
    Ok, that's good news. Well, how long is the slip yoke? I am worried that it will slip out. I guess I going to just pull it out, and check.
  7. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    I have a 4 in lift and never had a problem with it coming out. I think most the people on here with a 4in or less have a stock driveshaft. Over 6in then id get a longer one.
