driveshafts on 4" lift?
Discussion in 'The Garage' started by johnnieg, Aug 11, 2004.
  1. johnnieg
    johnnieg 1/2 ton status
    Nov 10, 2002
    130
    CSU, Ft. Collins, CO
    driveshafts on 4\" lift?
    Do driveshafts need to be extended with a TC EZ-ride 4 inch lift up front and a shackle flip in the rear? I don't want to put it on and have the driveshafts crap out on me. /forums/images/graemlins/k5.gif
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Re: driveshafts on 4\" lift?
    you should be fine /forums/images/graemlins/thumb.gif
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    most likely not just drop your t-case and you should be good to go /forums/images/graemlins/thumb.gif
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    I had to get a new front shaft( cost of extending it was 30 bucks less then a whole new one) for my TC6" the rear was fine but the yoke hangs out alot!!
  5. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I dropped my tcase, ord zero rates, shackle flip, 4 degree shims and all is fine!!!
  6. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    You will either need to purchase a new driveshaft for the front or have it re-tubed. I'm not sure on the rear driveshaft though. I would at least check it.
    I would give either of these guys a call. http://www.4xshaft.com/
    http://www.dennysdriveshaft.com./html/contact_us.html
    I installed a 4" lift kit and ordered two new driveline from Denny's. They are sweet and smooth. Now worries at all now. /forums/images/graemlins/peace.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your driveshafts should be fine. The front won't be an issue. The rear will be the fun part. The shackle flip will force you to play with the pinion angle. It may require dropping the tcase some and also adding some degree shims under the spring packs.
    I am running 5" lift on an 85 with a 700R4/208 and I run stock shafts front and rear.
    Harley
  8. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I am running stock drive shafts with a 6" lift and zero rates on my truck. Will need to get some shims for the rear driveshaft and drop your t case. With my 6 I had to take a grinder to the ears on the front but runs out great at any speed.
