Driveshafts too short?
Discussion in 'The Garage' started by ascuro, Oct 18, 2005.
  1. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    I just finished up installing a set of 6 inch springs on my 70 blazer, and I can see the very tops of the driveshaft splines, on both the front and rear shafts. It seems to run fine, but am I pushing my luck with the shafts like that, or should they be ok? They're stock shafts as far as I can tell.
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    What kind of trans and transfer case are you running?
  3. ascuro
    Sep 19, 2005
    62
    SoCal
    I've got a 350 and an NP205. Stock 44 up front, and 10-bolt out back too. I am planning on an axle-swap, but that's much further down the line (cash and wife-permitting =)
    I'm pretty sure they're not trail-worthy as is, mostly wondering if there's some particular point where they'd be unsafe on the street/minor dirt for now.
  4. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    I usually hear after a 6" lift you are also looking at longer drive shafts. I guess you could get away with it but most people will say that 4" of lift is about the most you will get out of your stock driveshafts.
  5. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Had to lengthen my front 2.5",the rear had to be made anyway with tranny transfer swap.
