Driveshafts used with 4" lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cheyenne_77, Dec 2, 2002.
  1. cheyenne_77
    cheyenne_77 Registered Member
    Aug 5, 2002
    38
    Melbourne, Australia
    Driveshafts used with 4\" lift?
    Can i use the stock 4 inch driveshafts with a 4 inch lift?Are they long enough? /forums/images/graemlins/1zhelp.gif
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Re: Driveshafts used with 4\" lift?
    Stock works.
    John
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Running the stock ones here. Will even work for 6" lifts if you don't wheel it real hard.
  4. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i used both my stock shafts with 5" in the front 4" in the back. i did need a front drive shaft spacer to get it to clear the cross member though. it was about $50. but if you have a lathe you could probably make one for about $7.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,074
    486
    Grand Rapids area
    [/ QUOTE ] If your driveshafts are only 4 inches long, they will never reach all the way.
    Seriously, though, a great way to make up for the extra slip yoke showing is to swap out the 10/12-bolt rear for a 14B rear. This moves the rear yoke forward about 2" and makes the stock driveshaft about "perfect" again (except for it's lack of 1-ton U-joints and a CV joint).
  6. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    Stock are working ok with my 4in lift. I did lower the t-case, but would love to just feel better about myself by getting new driveshafts and raising my tcase back to stock..
    Sergio /forums/images/graemlins/k5.gif
