Drivetrain guys NEED HELP ASAP!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Aug 18, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    this just started happening today, whenever i make a hard left or right turn, like out of a driveway, midway through the turn there is a violent and loud bang and right after the rear end feels like its trying to hop to one side or the other, almost like its been hit by a car and its trying to slide out from under the truck, something is obviosly broken or is in the process of breaking.
    its a 10 bolt rear, with a factory posi and 4.88 gears. Last time i looked at the posi one of the spider gears was missing a tooth. Any ideas, i need help fast, this is my only means of transportation. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    is it a posi or locker? my govlock will do that once in a while in reverse..
  3. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    im pretty sure its a posi-traction
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Not to sound rude... but are you serious? Busted spiders will cause that 10b to do all sortza wierd junk... not to mention popping, cracking, or FAILING... IE spitting out the axles on the street. IF the carrier were to fail... and it COULD... your C-clips could come away from the axle shafts thus allowing the shafts to exit the housing. /forums/images/graemlins/eek.gif
    I'd pull the cover ASAP and find out what is happening and SOON, seeing as this is your primary mode of transportation!!!
    -Dan
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Also, as a note... POSI and SPIDERS don't go together! If you see spider gears (inside the housing) then its an open carrier. Just as an FYI! /forums/images/graemlins/wink.gif
    -Dan
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    10 bolt gov-locs do have spider gears ALMOST just like a normal open carrier. the only difference is the toner rings around the outer spiders.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Id say your quality Gov-Loc is ready to go!
  8. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    ya ive come to that conclusion as well, ive asked around to see what kind of lockers eveyone uses and ive done some price and quality comparisons too, i think im going to go with Powertraxs' No-Slip Locker. Any feed back from you guys would be much appreciated /forums/images/graemlins/ears.gif
  9. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    Final Update
    just got the diff cover off, the spider gear on the left is missing 4 teeth in a row /forums/images/graemlins/eek.gif, the top gear is missing corners on three of its teeth, and the bottom gear is missing an entire tooth along with chunks of the teeth on either side of it. Long story short, im f***ed.
    Well hey at least now i have a reason to buy an aftermarket locker /forums/images/graemlins/thumb.gif
  10. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: Final Update
    DETROIT BABY! The only locker for the rear axle! Sorry to hear that! /forums/images/graemlins/frown.gif
    -Dan
  11. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Re: Final Update
    Now is the time you want to start thinking about getting a different axle. Putting money into a 10 bolt is not a good investment, I would try and find a replacement 10 bolt or something else completely *cough 14bff cough*. If you take it to a shop to get the work done, with all the metal floating around in your diff they will want to rebuild the whole thing and probably get you for a ring and pinion too. Don't make the mistake of putting $2000 into your 10 bolt.
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: Final Update
    [/ QUOTE ] no $hit, junk the 10bolt for a good 14bsf that is 6 lug or go al out with a 3/4 ton swap witha 14BFF.
    85K5 3/4ton,14b0ltFF,10bolt,9"lift,35"boggers,16.5x14welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Final Update
    My rearend in my DD bangs an clunks every day, but it has a Lock-Right in it!
  14. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    exact same thing mine did before it cracked in half. /forums/images/graemlins/thumb.gif
