drivetrain problems with 4 in. lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Jun 22, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    i just got done with my 4 in lift, and the rear driveshaft binds at both u-joints. Also it looks as if the yoke is about to fall off. Will the t-case drop fix that, or do i need to get a new drive shaft?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Well...You might want to drop the transfer case first,and see if that helps..When I got my lift my shaft was about inch and a half too short (kept on going through U-Joints) I have 2 inch blocks in the rear with add-a-leaves...Alot of people I know on this site have gone up to 4 inch lift's without changing ether driveshafts...
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    Also did you use any degree shims on the rear? Helps with driveline angles.
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, need more details. What kinda lift and components are we taking here?
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    You should do this more often !
