Drivetrain Q
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Dec 6, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    What is it called where the driveshadt meets the rear diff? I think its leaking AGAIN!!!!
    ok thanks
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
  2. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Do you mean the pinion on the rear diff?
  3. NOT4SHW
    NOT4SHW Guest
    That would be the "pinion seal"!
    '79 K5,13 1/2" lift, 39.5 TSL's,15x12 Eagles,350,t-350,warn 8274
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How easy is the pinion seal to replace? Mine is leaking too.
    My Chevy isn't broken, its just out of gas.
  5. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Yeah thats what i was thiking, thanks.
    305/Sm465/ NP208
    Kn, 4.56's.
  6. GMCFIRST35
    GMCFIRST35 Registered Member
    Dec 2, 2001
    38
    LARAMIE,WY
    yeah its the pinion seal and it pretty easy to do all you have to do is take the driveshaft off and the yoke on the diff its one nut its alot easyer if you do it on the ground just put the parking brake on
  7. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    You use a torque wrench to find out how tight it has to be when you put it back together. Very important. Remove yoke pop seal and instal is in reverse. Easy.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
