drivetrain question
Discussion in 'The Garage' started by beater_k20, Dec 23, 2005.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    so i've been kicking around some ideas for either my K20, or its replacement in the drivetrain department. i've come up with a few ideas, i definitely want to stay gas powered, and i want to stay small block. the original idea that i had was a full roller 383, that should make somewhere near 460 ft/lb, and have a relatively flat torque curve. i found out yesterday that a local guy has a virgin 400 shortblock, so i plugged the extra bore size into my 383 formula, adjusted the SCR to achieve a good DCR. its low enough that with the Vortec heads i could safely run 87 octane, although i'd probably run 89 in it just for the little extra safety. what i came up with is a 406ci engine that will make nearly 500 ft/lb from 2000(lowest any of my engine programs will go) to 4000, which is where i'll be using this power. i'd like to stay auto. will a stock TH400 stand up to this kind of power? i'm also tossing around the idea of a 4L80E, as i'd like to knock down the gear ratio a little and drive the thing once in a while. will the 4L80E stand up to it?
  2. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    yep and I would go with the 400 got to CI :D
  3. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    4l80e is as tough an auto as you can get in a pickup. It'll live. If ya pick up that 400..........stroke it! A buddy has a 434 SBC dyno'd at just over 500hp 500ft-lb. with 7.17's in the diffs. Stout puller I tell ya.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    torque peak isnt nearly as flat with the 434, and it would be considerably more expensive. the other engines would be just basic rebuilds, using hypereutectic pistons, a set of used 5.7 PM rods i have laying around, the Vortec heads, and a Vortec intake. the only real expense different from a normal build would be the roller cam and correct lifters for the 400 block.
  5. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I understand that this wouldn't be a basic job, he's got about $12,000 into his incl. aluminum heads. I've got a copy of his dyno sheet somewhere online. I'll try to find it. I don't recall his tq curve being sharp but can't remember exactly, he built it a couple years ago now.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The TH400 is the cheapest & strongest IMO. It will hold up as well - if not better - than a 4L80E.
    I would also go to 400+ ci. Lets face it - a V8 is not going to be economical, so you might as well have all the power you want.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    economical? probably not. but why build a truck that's a gas hog just because, ah hell, its already got a V8 in it. with 450-500 ft/lb on tap, i dont think getting reasonable milage is completely out of the question. hell, it will probably do better than my existing worn out stock 350, which already gets 12mpg backed by a 350/203 and 4.10s on 31" tires.
  8. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I can't find it, must have gotten lost in the great interweb. I personally prefer a more stock build, but I just can't get over how that thing pulls.
    But more accurate specs are
    Aspiration: 850 CFM Q-Jet
    Engine Mods: Small Block 400, Bored 30 over, 4 inch forged Stroker Crank, 434 cubic inch, AFR Aluminum Heads, Lunati roller cam, full roller valve train, 10.6 - 1 compression
    HorsePower: 485 @ 5500 RPM 540 lbs trq @ 3500 RPM
  9. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    your getting 500 ft lbs just from vortechs, slightly higher compression, manifold, and a cam?
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    according to my engine programs, yes, i am. the 383 version is at 9.11:1 SCR, and the 406 version is at 8.84:1 SCR. using a Comp Cams XR258 roller cam. the flow info i have on the Vortecs is VERY close to what i have seen in real world situations on the flow bench.
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If it were me i would buil a 383 and stay away from the crack prone 400 SBC. The 400 chevy blocks seem to crack quite often in the lifter valley area and pretty easily too i might add.
  12. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    As far as the 400 blocks go, the 2 bolt main is known to be more desirable for strength than the 4 bolt main 400s. Sounds backwards I know, but the outside bolts were drilled into a weak part of the block and known to crack the webbing under high horse and high load conditions.
  13. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    4L80E should be able to hold up. im debating bout either a built 700r4 or a 4L80 for my next tranny, when my stock 700r4 goes, its jus a matter of time.
