Drivetrain Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Aug 19, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I gotta question for all you guy's out there... I gotta tranny out of a suburban, the axles rear 14 bolt front 10 bolt??? I didnt know they made a front 10 bolt in 8 lug though??? what transfer case do I need to bolt to the th400 tranny???
    [image]http://www.inhomenetworking.com/images/littleblue.jpg[/image]See me at <a target="_blank" href=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</a>
  2. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    What case do you want to use? You can put anything you want back there, it is just a matter of using the right output spline count and adapter. What year is the trans? That will tell you what came behind it originally &amp; what will be the easiest to put back.
    Jim '80 GMC & '73 Blazer
    Tread Lightly!
    <a target="_blank" href=http://www.gmck5.rockcrawler.com>www.gmck5.rockcrawler.com</a>
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yes they made 8 lug 10 bolts, that was the Dana 44 replacement. As far as the t-case you can go with a 203, 205, 208 were the most common.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  4. reddog64
    Nov 9, 2000
    3,325
    If it had the np208 and I want the NP205... where can i get an adaptor for it??? or is it easier to get a th400 that went with a np205... even a np203 would be fine... i liked the last np205 I had...
