drivetrain vibrations
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dmeyer, Feb 28, 2002.
  1. dmeyer
    dmeyer Registered Member
    Feb 18, 2002
    6
    Illinois
    I have a 90 fullsize blazer. The rearend is just rebuilt and I put in new ujoints on both ends of the rear driveshaft. When coasting to a stop from 40 or about 50 there is an almost grinding noise that sounds like it is comming from the transfer case or an area around there. It only happens at those speed when I let off the gas till about 30 then it goes away. I cannot tell any major vibrations in accelerating or cruizing but sometimes when I take my foot off the gas it makes that noise. Thanks for any help in advance.
    Later
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Sounds like your rear diff is starting to wear out. If the bearing are worn out then there will be play inside and start to make a rattling noise. Do you also hear a high pitched whine as you're driving down the freeway? That would be the ring and pinion not meshing correctly. Also make sure the t-case is filled with fluid and not running dry along with the diff.
  3. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    My 1989 Blazer does the same thing... can't pinpoint it just yet.. I'm thinking t-case bushings are shot.. i've replaced just about everything else..
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  4. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    I had a simular problem also I put in a polyurethane t-case mount and it cured it .........
    1988 k-5 blazer 5.7
  5. dmeyer
    Feb 18, 2002
    6
    Illinois
    Thanks for all the replys. The transfercase mount sounds interesting, I will have to give mine a look. 1Bad 88 did your old mount look bad or was it something that you couldn't really see?
    The whole rear end has just been rebuilt, not even a hundred miles yet so I hope that is not the problem. Rocko, if you figure it out let me know, that would be a great help.
    Later
