Driveway Clean up?
Discussion in 'The Garage' started by CHEVY 4WD, Jun 13, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Well I discovered a 3/4ton swap isent really easy with just one floor jack. And it is VERY messy So I started the project and get all kinds of oil and greese on my parents asfalt(blacktop) driveway needless to say there not happy SO is there ANYTHING that I can use to clean this? I was planing on trying geese lighting and scrubing it then using a gas powered pressure washer but im not sure if that would even help any help I REALLY NEED THIS CLEAN /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    spray some brake cleaner and gas on the driveway and light it, i bet they wont be worried about grease stains anymore...wait, already tried that, didnt you?
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Since Asphalt will "melt" with any decent cleaner, Your only choice is a pressure washer with just water to blow the crap off. /forums/images/graemlins/eek.gif
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    2000 psi water...
  5. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I've used Spic 'n Span with a stiff bristle brush on concrete with fairly decent results. That was over 20 yrs ago though, do they still sell that stuff? /forums/images/graemlins/confused.gif
  6. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    dawn dish detergent,stiff brush and hot water helps
    dont put the dawn directly on drivewayor call por 15
    for marine clean www.por15.com
  7. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    a rag and some gas, i prefer 93 octane, and wipe it off, works wonders, my dad showed me this trick because i made a massive oil stain in our already stained driveway. /forums/images/graemlins/grin.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    OK, I don't have any suggestions on cleaning the driveway, but I just have to ask.... How in the hell did you make such a mess while swapping axles? /forums/images/graemlins/shocked.gif I've done the 3/4-ton axle swap on 2 different rigs and never spilled a drop of oil or grease either time. I can see losing a few drops of brake fluid when you disconnect the rear line, but that's easily captured in a catch pan. So, where did all this oil and grease come from? /forums/images/graemlins/eek.gif /forums/images/graemlins/wink.gif
  9. Confedneck
    Nov 1, 2002
    5,236
    harry, well, we took the diff covers off, and cleaned the diffs out and then while moving them it all spilled out, so there's about 2 or 3 quarts of diff oil mixed with gas, brake cleaner, mineral spirits, oh and we sprayed the axle tubes periodically with gas to break up the rust we were wire wheeling away...
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Luckily, you're still alive to tell us about it. /forums/images/graemlins/eek.gif Using gas a solvent is NEVER a good idea! /forums/images/graemlins/shocked.gif There are plenty of non-flammable solvents available to do the job...
    And next time, wait until the axles are installed in the truck before you remove the diff covers. /forums/images/graemlins/wink.gif
  11. Confedneck
    Nov 1, 2002
    5,236
    psshhht he wouldnt let me spray the gas on then light it to burn the rust off, not sure why LOL
  12. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    UHH last night we did and we blew a flame from nitro methane about 25 FT too /forums/images/graemlins/grin.gif
  13. Grim-Reaper
    7,385
    Atlanta
    Reseal the WHOLE driveway.
  14. Confedneck
    Nov 1, 2002
    5,236
    why would we re-seal it, it hasnt ever been sealed, DOH!, but i figure a couple (see hundred) boxes of SOS pads and a bucket or two hundred of water would work...LOL
