driveway gear swap (Difficulty)
Discussion in 'Pacific Region' started by dabears73k5, Sep 16, 2006.
  1. dabears73k5
    dabears73k5 Registered Member
    Jul 27, 2005
    52
    El Segundo, CA
    Ok, i love the thrill of doing most of my work myself on my rig. When i first got it i through on a 6" lift, rewired the complete truck, installed a soft top and put in a carpet kit (which is getting torn out for a bedliner finish). I ma tempted to do the gear swap myself but was wondering about which special tools will be needed, and if you can do it with out a press? Any feed back would be great.:1zhelp:
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Probably be better off finding someone who already has all the tools and the know-how to do it.Mine just cost me a few beers...:D
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Can do it w/o a press, but that makes it more difficult.
    Highly suggest you find someone who's done it b4 to at least guide you thru it, if not do it with your help.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You need a good set of calipers and dial indicator w/ mag base. You will also want to use a press. You can get away with a bearing separator on the smaller axles, but if it's a 14B, forget it. You need a press.
    I have done several different types of axles and they all have their different quirks.
    If you really want to do it yourself, do a LOT of research. There are a couple install videos kicking around out there that are worth their weight in gold for the info they have. I'll see if I can't dig up the one I have. It's pretty good. Kind of like a "gear swaps for dummies". Maybe that's why I like it so much??:confused: :haha:
  5. 1BEATK5
    1BEATK5 1/2 ton status Premium Member
    Dec 15, 2005
    2,735
    32
    beaverton orygun
    for a first timer on a non 14b axle i would suggest a set up bearing kit, so you wouldn't have to worry about being able to change the shims under the bearings without the proper and expensive bearing tool.
    just set the axle up with the set-up bearings first (they are not a press fit), and once you have it right you put the real bearings on.
