driveway stains
Discussion in 'The Garage' started by 86chevybanshee, Jan 3, 2005.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i got a bunch of oil, tranny fluid, and gear oil stains on my asphalt drive way. does anyone know the best way to get them out?
  2. semper-k-five
    semper-k-five 1/2 ton status
    Aug 16, 2004
    326
    Tulsa, OK
    local auto shops may have something specific...i've always wasted a can of engine degreaser...spray it all into a bucket of hot water...mix it up good and get to scrubbin...spray it down and looks brand new!
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    that or the meritic(sp) acid stuff works awesome you can get it at any hardware store, just poor it on there give it a lil scrub and rinse :xmas:
  4. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    for smaller spots, i've had luck with liquid dish soap that cuts grease. but i think the oil spots were fairly fresh.
    auto parts stores have kitty litter stuff. when i worked in the store we used it in the lot.
  5. blind driver
    blind driver Registered Member
    Oct 9, 2004
    11
    Louisville, KY
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    1 quart of Tide laundry detergent in 1 gallon of hot water. Mix it well, pour it on, let it sit for 10-15 minutes, scrub with a stiff bristle brush, and rinse. Much safer than muriatic acid - Tide won't burn your skin or kill your grass & pets.
  7. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Brakleen works for me.. spray it on and hose it off. Little spendy if you have it everywhere.
  8. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    lots of ways to erase oil stains
    If its on asphalt,its much harder to get rid of oil stains than cement--muriatic acid works,but is deadly to pets and grass,and even one drop in your eyes will be disaster--I use speedi-dri on big spills first,when the majority is mopped up with that,Castrol Super Clean scrubbed in with a brush,or laundry detergent will help cut the grease,I've used easy off oven cleaner too with limited results---the bottom line is you aren't likely to get ALL the stains out with anything you use,but you can try TSP--Tri-sodium Phosphate,sold in paint stores,scrub it with a brush like the detergent--they claim if you cover the spill with speedi-dri,and soak it with paint thinner it will lift the stain into the speedi-dri as the paint thinner evaporates....
    I've tried them all,but still have a big oily mess where my 82 GMC Cabalaro leaked dextron and motor oil on the driveway--one thing I've learned,its a lot easier to put a mat of cardboard or a peice of plywood or other stuff(homosote,, or masonite board will catch the oil,and once it soaks in you can burn it) under the car or truck,and to mop up any spills quickly,before they get to soak in--I've tried pouring lighter fluid on it,and lighting it,and letting it burn--it smokes like hell,softens the asphalt,but some of the oil did burn off,but the tar will never be the same!:blush: --the only thing that will remove them completely is time--after 12 years,the spot my 72 K5 oozed gear oil all over the drive has no trace at all,except for a darker shadow where the 90W used to be--I guess acid rain and 12 years is one way to get those stains out!!...:crazy:
  9. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    well the drive way is less than a year old, my old man just flips a sh** anytime something other than water gets on it, and having and old chevy dosnt help
  10. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I've had good luck with "Greased Lightning". Wallyworld, Dollar Stores, and most supermarkets carry it. Gets the grease out of clothes, too:waytogo:
    John
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    diesel + hot water pressure washer :)
  12. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    My dad used to flip out too!
    Dont feel alone--my dad is the reason I know so much about driveway oil spill removal too--he used to go ballistic when he saw anything spilled on the driveway--I learned too late to park in the woods next to the driveway,and not to leave the truck on the asphalt--he was always watching me very closely while working on my trucks too,and more than once I spilled some oil or tranny fluid due to just being paranoid I would!!:blush:
    Well,my dad passed away in april of 2000--the stains were pretty much gone from the spots he always complained about by then--and he did say to me once he was sorry he got so angry about something that wasn't really that big of a deal,he just felt it was disrespectful of me to treat his hard earned property like a junkyard--but he did say he was impressed with all I had done to my trucks,mostly alone,since he was bedridden with parkinsons disease--I miss him a lot--but I can still hear him yelling at me for spilling that gear oil!!:blush: :frown1:
    Oh yeah--if you try a pressure washer,dont use one with more than 1500 psi--I borrowed a 3500psi one from a friend,and washed the offendng spot in the driveway--most of the tar blew 15 ft away into the woods,leaving a huge crater--I thought he was mad about the oil spill--that was NOTHING compared to "hydro blasting" the asphalt right into the next yard!!:frown1: --that spot is filled with concrete now...:blush:
  13. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    spread kitty litter, then take a liter or two of coke and dump it all over the kitty litter. Dont ask me.... but it did work once or twice...
    now i just use a pressure washer... and some bleach....
  14. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
  15. dyeager535
    26,982
    191
    I've used JUST a hot water pressure washer on a concrete driveway before to clean whatever oil/fluid I spilled on it off, and it worked great.
    Only problem was that the rest of the driveway ended up looking dirty because those spots were so clean.
  16. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Go to Checker, Shucks, or Kragen and find the stuff called Oil Eater. It is biodegradable and will get your driveway really clean. It works as good or better then degreaser or brake cleaner, and you don't hurt the environment. A gallon cost me $9.
    Harley
