Driving around in over drive
Discussion in 'The Garage' started by surpip, Mar 7, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I had a discussion with my GF about driving in OD, she says its fine(dosent know a whole lott about cars but isent car dumb),
    I think it is a bad idea, as i was told it would wear out the tranny faster.
    Car in question is a 04 honda civic.
    Please only reply with facts not just"my dads uncle said its ok"
    thanks
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    My truck shifts into OD at 30mph if i let it, and its been going strong for over 200K miles. I cruise arround town in OD turning less than 1000 RPM's.
    Cars today i wouldnt worry about. They compensate to hold gears longer until better opperating temps are reached in both the engine and tranny before running in OD.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    on the older overdrive trannys yes it was a BIG deal to not put it in overdrive in town and only use it on the highway or at substained speeds over 50 mph. on the newer trannys its not as big of a deal but i would still only use overdrive at speeds over 50mph. it never good on a tranny to constantly be shifting in and out of 4th
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    It shouldn't be a problem on newer cars since they are designed and tested to be run this way. The new electronic control transmissions typically do a lot better job of avoiding the "shift-hunt" condition that caused the problems for older vehicles. On my '90 K5 I always kept it in D until getting up to speed on the highway and then shifted into OD, on my '03 2500HD I just put it in gear and go........I've never noticed any hint of any shift-hunting on it.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    car wont evne be in final gear(overdrive) til its evn going fast enough to make it, OD is final gear, it wont skip 2 or 3 to get to OD, it doesnt work like that, honda, chevy, ford, anything, can drive around in od range all you want in town but doesnt mean you be in od, unless youre going fast nough for it to make it to od gear
    good luck
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The indicator on mine says "automatic overdrive" above the letters , but its d-3-2-1 no overdrive listed , its "automatic" . With the right gearing , just like factory combo , it can stay in D or D with the circle around it for later trucks .
    It should not kill the tranny in normal use by normal people :k5: :k5:
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Cool thanks guys, I guess it all depends what school of thought you come from, if it was my car i wouldent drive around town in OD but i guess it wouldent hurt it huh?
    thanks again:D
  8. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    "It should not kill the tranny in normal use by normal people"
    so this counts me out huh???:blush:
