driving in a straight line
Discussion in 'The Garage' started by Mo_Bedda, Sep 14, 2002.
  1. Mo_Bedda
    Mo_Bedda Newbie
    Sep 14, 2002
    San Francisco
    OK, here goes nothing. I thought since I just got this new project I would post here before starting to replace parts to fix this issue. I have a blazer I just got it has 33x14.5x15 tires on it the front end looks fine I checked the ball joints, steering box, sway bar bushings and for the life of me can't get this thing to drive in a straight line I have to constanly have to correct and over correct to get this action to happen - anyone have any idea's. any info would be most helpful.
    Cheers
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    have you taken it to an alignment shop and had it aligned?
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Might have a cracked frame at the steering box...also having tires that wide doesn't help
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Check the pitman arm to make sure it's tight on the steering box. My steering is pretty tight since I found out that's what the problem was.
