Driving on a Titerope
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dmanblazer, Jan 15, 2005.
  1. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    I just started driving my '79 K5 after putting a 4" lift on it ( springs front/blocks rear ), and it seems like I'm driving on a titerope. I bought the lift used from an "82 Blazer, I used the complete frontend ( 10 bolt corperate ), and just the springs and blocks on the rear, the shocks are Rancho RS 5000s that came with the lift. The only thing different I did was, the donor K5 had the Z something package, I can't remember the package number, but it had dual front shocks, and my K5 doesn't have the extra bracket or hole in the frame so I just left one off on each side. I took it to get aligned at midas and they said my right side ball joints were bad and my left side had a little slop in them but not much, so I replaced the right side and did nothing to the left. The spring hanger bolts on both trucks had to be cut off so in their place I put grade 8 bolts as close to the same diameter as I could but they are still a little small. Does anyone have any ideas on what the problem is? This is my families only means of transportation since our Trans Am was stolen and I need to get it fixed. Thanks, Jeff
  2. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I'm not sure I understand what you mean by "tightrope"????
    Is it wobbly, topheavy, vague steering????
    Some better details about the symptoms will probably get you the answers you need.
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Maybe you just need a longer balancing pole.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well for starters remove the front shocks and get a single unit meant for single apps . I believe the dual shocks together equal one shocks . The reason for dual shocks is to prevent shock fade :k5: :k5:
  5. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    I have never driven on a tight rope before. How's that feel? :grin:
  6. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    Probably like death wobble and bumpsteer!!
  7. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    When I'm going straight down the road it does fine but if I move the wheel left or right just a little bit it feels like it wants to wander like it oversteers.:confused:
  8. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Did you use any type of steering correction. Raised steering arm, dropped pitman arm, or drop drag link?
  9. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    Dropped pitman arm
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    what size tires are you running?
    The spring bolts should be 9/16" all the way around except the front shackle bolts should be 7/16" (1/2" on updated models). To be close you either have some goofey metric bolt (14MM won't fit and 13MM is nearly 1/2") or a 1/2" bolt in the springs. This is hardly close in size. You need to go the the hardware store and get yourself the correct size bolts (grade 8).
  11. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    Well I put the correct rancho's ( # RS 5001 ), but I'm just now going to test drive it
  12. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    Well it helped a little, but I know that one of my back shocks is bad so I'll change them next week. What is the best bushing kit to buy nowdays? I would like to replace every bushing and body mount on the truck.
