driving sideways?
Discussion in 'The Garage' started by shaun89, Dec 13, 2005.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i put a 6" superlift on my truck, all 4 springs, and 38s....now my truck is crab walking down the road, is it just the alignment, or something more? i dont like it too much:confused:
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Alignment won't cause crab walk, something is out of square. Check to make sure the spring pins are in the holes, or anything else that would cause unequal measurments between the front and rear tires. Measure from front hub to rear hub on both sides, are they the same? If not, find out why. If yes, then measure diagonal (not easy) front to opposite right. that checks for "diamonding" which can result from a warped frame among other things...
  3. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    when did you install 4 wheel steer? the other night!? musta not been paying attention...
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    So was it ok before the new springs? My SkyJacker rear springs have the holes moved forward from the normal location, I'm guessing for driveshaft length issues. Are your rear springs the same from left to right? Measure from the front spring eye to a place on the axle, the top of the threads of a u-bolt would work good. Measure the other side and compare.
