Drop drag link, or drop pitman arm?
Discussion in 'The Garage' started by **DONOTDELETE**, Mar 19, 2002.
    I am lifint my truck another 4" and I was wonder until I go crossover, what is better to correct my steering? The drop drang link or the drop pitman arm. The drag links are going for about $120 vs. $60 for a drop pitman arm, so if it's not going to make a difference then I save some money and get the pitman arm. Also how hard is it to remove the pitman arm from the steering box? Thanks
  1. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    If you plan on putting a crossover on then I would definitly save your $60 and put on a drop pitman arm. That would put you closer to a crossover./forums/images/icons/smile.gif Now if your going to wait for a year or so for the crossover then I would probably spend the money and get the drag link. With the drag link you will get a little more articulation then you would with a drop arm. As far as changing the drag link it is very simple. Just use a ball joint seperater (think thats what its called) and knock it off.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you are NOT doing the crossover steering, and just the factory setup, just get the 4" raised steering arm for around $50.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I think from what you are saying you are going another 4" to give a total of 8" correct? With that much lift you might as well do crossover and be done with it. Also with that much lift there are going to be alot of other issues to fix. Driveshaft length, pinion angle, brake lines are just a few things that might need changed. For just a temp. deal I would try the pitman arm and then see if you need anything else.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    A bent drag link is useless in dealing with bump steer issues. It has exactly one purpose for the short drag link (clearance is another potential use in cross over). That singular use is for correcting angles at the drag link ball joints. That's it. For the best steering characteristics what you want is a straight line between the two ball ends that is perfectly horizontal (level to the ground) and the ball ends positioned so that the cups do not bind on the pin at any point in the axle's movement. You could twist the drag link into a pretzel and, as long as it is rigid, it would make no difference to bump steer. So, for the best solution with a stock setup (short link on the driver's side) use a drop pitman and/or a raised arm to get the straight drag link horizontal.
    BTW, a drop pitman now will be no use in a cross over later. The pitman arm off a 4WD box will not fit the 2WD box required for the cross over.
  5. When going to 8" I am aware that the driveshafts are going to need lenghtining, the brake line might not be long enough, and my pinion angle is going to be off. I can correct my pinion angle with angled wedges right? I really dont want to move my spring perches. My friend has a 10" lift and he did'nt move his, to the best of my knowledge. Thanks for your help.
  6. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You should be ok to use shimms.
  7. barbastard
    barbastard 1/2 ton status
    Dec 7, 2001
    289
    Pleasant Hill, California
    just for the record the item you described here:
    "As far as changing the drag link it is very simple. Just use a ball joint seperater (think thats what its called) and knock it off. "
    is called a "pickle fork"...at least that's what I've always called it.
    just for inquiring minds....not then anyone really gives a rats ass....
    later..
    Barbastard
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a pickle fork usually damages something
    there is a clamp type that doesnt
    or BFH on the side of the female end(not the rod end) and they usually pop out
