Drop np205 1 inch with spacers
Discussion in 'The Garage' started by cegusman, Mar 1, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I just swaped in a sm465/np205 from a 700r4/np208. On the 208 I dropped the crosmember the recomended 1 inch whith the factory spacers, but is that needed with the np205?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You'll have to drive it and find out. Your rear driveline should be longer now so maybe you'll be OK.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It depends - you have to check your driveline angles and see.
    I'm not a big fan of dropping the tcase - it's just kind of butch. But if you need to, you need to.
    If it helps, I have a longbed pickup with a 465/205, about 6.5" lift, and did not need to.
    -- Mike
