Drop Pitman Arm
Discussion in 'The Garage' started by msb350, Sep 3, 2005.
  1. msb350
    msb350 Registered Member
    Jul 6, 2004
    96
    Texas
    I was wondering which companies made a drop pitman arm for my 89 K5. I think I remember seeing skyjacker or superlift a while back but I am not sure. I need it for a 4in lift. Thanks.
    Matt
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    agreed raised steering arm will fix it, and its alot cheaper than drop pitman arm
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    A raised steering arm will only cause horrible bump steer. You are correct in trying to find a dropped pitman arm. I don't know who makes them, but you can call www.tyres1.com or www.natltire.com and they should be able to help. Steven at www.offroaddesign.com may have them also.
  5. msb350
    Jul 6, 2004
    96
    Texas
  6. divorced
    Jul 20, 2004
    5,115
    Yep, that's what I would run for a 4" lift. You want your draglink to follow the arc of your spring, not be level (unless you have flat springs).
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    pardon my ignorance.. I'm still learning :bow:
  8. msb350
    Jul 6, 2004
    96
    Texas
    Its all good. That is the reason I asked about the pitman arm, its all still new to me.
