Drop pitman or not???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Oct 9, 2002.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    O.K. I have a 4" lift... stock pitman arm... turning to the right sucks /forums/images/graemlins/eek.gif I have read that a 3" drop arm will help...Is this true??.. I know cross-over is the way to go but at this time not feasable... /forums/images/graemlins/k5.gif
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    Just get a raised steering arm (the arm attached to the axle itself)--its cheaper do a search to get it off---
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so are you saying the turn raidus is better one way then the other?
    if so you need to adjust your draglink length
  4. rcpilot
    Feb 22, 2002
    507
    Central Cali
    Yes.. to the right it's on a dime but to the left not so good.. the link was adjusted with the wheels straight to center the steering wheel.. did I do it wrong??
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It could be off by a full turn...make sure from the center to each lock is the same amount of turns...should be aobut 1.75 each way i think
  6. rcpilot
    Feb 22, 2002
    507
    Central Cali
    90K5.. thanks I'll check it tonight...
