Drop Pitman vs. raised steering arm
Discussion in 'The Garage' started by 1987Chevy, Jun 29, 2005.
  1. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    I was wondering which would give a better steering angle on a truck with a 4" lift, a drop pitman arm with a stock steering arm or a raised steering arm with stock pitman arm?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  3. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    Something else to think about, a dropped pitman arm puts more strain (direct leverage) on the sector shaft. They can & do break, esp when wheelin'.
  4. divorced
    Jul 20, 2004
    5,115
    ... but a raised steering arm can/will cause bumpsteer.
  5. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    go w/ drop pitman arm for a 4" lift. i used the raised arm and had bad bumpsteer. switched to the drop pitman arm and almost all bumpsteer issues went away.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have a 4" lift and used the stock setup for a long time (stock pitman arm, stock draglink, stock steering arm) and had almost no bumpsteer. with my recent axle swap i desided it was time to put my raised steering arm on. the bump steer is so bad, if i step on the brakes with my hand off the wheel, the wheel turns. i recently went wheeling with it and there were points that i couldn't even turn. i had to back up to get the front axle near level again to turn the wheel. go with the drop pitman arm.
  7. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    fix causes bump steer?!
    i've got a truck with about a 4" lift and i have the death wobble bump steer. part of it is play in the tie rods, that will be fixed soon.
    There are reports in this thread of the raise steering arm causing bumpsteer?
    :confused:
    Isn't the same result accomplished by a raised steering arm and a drop pitman? Reduce the angles in your steering caused by raising the suspension?
    i'm looking at about $60.00 for the steering arm and twice that for the drop pitman, so for me it was a no brainer, especially since i replaced the drag link not too long ago. now that i see others mentioning problems with the raise steering arm solution i would like to hear some more opinions...
  8. divorced
    Jul 20, 2004
    5,115
    The raised steering arm will correct for more lift than the dropped pitman arm. A common problem when using a raised steering arm with 4" of lift is that it will "over-correct" and cause a bad drag link angle.
  9. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    wat about using a steering arm with 4" springs and 0rates?
  10. divorced
    Jul 20, 2004
    5,115
    Well, you're caught in the middle. I've never run that combo, maybe someone who has will fill us in. :ears:
  11. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    That is what i'm using (raised steering arm, 4" springs, 1" zero rate) and the bumpsteer is no worse than stock.
  12. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    I am running 4" springs up front with a raised steering arm and my truck is plain old scarry to drive! It wanders all over th road and has really bad bump steer! I have not tried a drop pitman arm since I dont drive the blazer much right now. The D60 I bought has a raised steering arm on it and it looks really tall and I think it is gonna make my steering even worse so I think I will switch to a stock arm and a drop pitman arm when I swap the axle in and hopefully it will help my problem. Anyone know where I can get a stock D60 steering arm?
  13. divorced
    Jul 20, 2004
    5,115
  14. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
