drop steering arm vs. drop drag link???
Discussion in 'The Garage' started by KevinsK5, Dec 5, 2005.
  1. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    When you lift a straight axle 73-up chevy is it best to use the dropped steering arm supplied with the lift kit, or buy a dropped drag link? For now I plan to keep it cheap and use the stock steering setup but maybe in the future I'll buy a crossover steering kit. For that I have a pair of flat top D44 knuckles and they're out of a half ton. I'm assuming it doesn't matter if they're out of a 1/2 or 3/4, they're exactly the same right? Thanks, Kevin
  2. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I'm just using a steering arm and have had no problems.
    knuckles are not the same 1/2 ton are 6 lug 3/4 ton are 8 lug
  3. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    The knuckles are the same.
  4. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    I did not like the feeling with the dropped arm went with dropped drag link was better but then went with the sky x-over steering great!! jm .02
  5. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    Throttle Boss, where did you get the drop drag link? Thanks, Kevin
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
