Drop steering arms?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Musclerodz, Dec 31, 2006.
  1. Musclerodz
    Musclerodz 1/2 ton status
    Apr 23, 2005
    121
    Washington, OK
    Installed 2 1/2" lift springs on my '69 K5 and need to correct the steering to eliminate the added bump steer. Where can I buy dropped steering arms? Thanks
    Mike
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    for only 2.5" all you could do is a 2" dropped pitman arm.
    a steering arm would give ya 4" of correction.
    my brothers 84 blazer had the 2.5" rancho kit and had tall the stock steering with no steering wows.
  3. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    with only 2 1/2" of lift, I personally wouldn't do anything.
  4. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    The 69 should have the closed knuckle front end. If so, your only option is an adjustable drop drag link. The 4" drop steering arms won't bolt up. I am using an adjustable drop drag link I bought from Offroad Design and I think it is from Skyjacker or Superlift, not sure which.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    For future use, the steering arm on the knuckle is called a RAISED steering arm when you want to raise it. The arm does not drop down, it raises up.
    The pitman arm would be called a DROP pitman arm since it will drop the arm down.
  6. Musclerodz
    Apr 23, 2005
    121
    Washington, OK
    Mine is an open with discs.
    Mike
  7. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    That is good. I would contact Offroad Design and see what they have to help you. Are you having alot of bump steer with that amount of lift?
  8. Musclerodz
    Apr 23, 2005
    121
    Washington, OK
    I have not checked yet as I am still assembling it, but I know I will have bump steer issues unless I correct it. You can't alter suspension height without affecting steering geometry even with 2" lift. I mainly am looking for vendors to buy arms from.
    Mike
  9. 300stw
    300stw Registered Member
    Jul 4, 2002
    51
    Culbertson Montana
    i have 2 1/2 in springs on my truck i tried the dropped steering arm(bad idea) i tried the dropped draglink( the link moves up and down when turning truck still wanders, then the 2in drop pitman arm, truck drives like new.....
