DROP THE T-CASE?
Discussion in 'The Garage' started by CHEVY 4WD, Mar 16, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    How do you drop the T-CASE? (208) /forums/images/graemlins/confused.gif
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Pretty simple. Place a jack beneath the T case to hold it up. Remove nuts and bolts. Lower the t case an inch or two. On these bolts should be 1" spacers. Place these spacers between the frame and t case cross member. jack it back up and replace the hardware. No need to remove drive shafts either.
    However, if your going to be doing alot of banging around go with 1' stock or square tubing. I smashed my t case on the some rocks and the frame kind of curled back into itself. So the spacers aren't really beefy. Good Luck
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I assumed you were talking about lowering the t case by the way /forums/images/graemlins/blush.gif
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    How does it still line up with the tranny?
  5. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    you never un bolt it from the tranny, in droping it the t case, tranny and motor all move(tilt) back as one unit
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What combonation of lift, axles, etc are you running. I actually found that after I installed my 14bff that raising the Tcase took out my vibs. (w/2.5" lift)
    With my old 10 bolt and 2.5" lift kit I had to lower it to get the vibs to go away.
    Also when you lower it check for clearences underhood after you lower. Check the fan to fan shroud clearence. (my fan ate some of my fan shroud after the drop when I flexed it) Also check the distributor to firewall clearence. It shouldn't be a problem, but it doesn't hurt to look and make sure.
  7. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    I think theres some confusion here becuase milspec forgot to mention that the bolts youre removing are the bolts that hold up the crossmember that runs right next to the t-case. Lower the crossmember an inch with some spacers inbetween the frame rails and the crossmember and bolt back up. As long as youre an inch or under, you dont have to worry about making any other mods.
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    "Drop" is not realy the right word. Think "tilt" and it will make more sense. Those factory spacers are not realy big enough in diameter, make or buy some that that will spread the load better. National Tire & Wheel http://ntwonline.com/ sell some nice aluminum ones if you arn't up to making your own.
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    nothing wrong with the factory spacers... they managed to carry the load of my tcase for the first 16 years of my rigs life when they were on top of the frame... and they have done just as well below the frame for the last 2 years.
    j
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    As always YMMV, but I've seen them cause a problem or two.
  11. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Same here my stock spacers have held up well for the 208 and even on the 203 that I've been sport'n around for 2 years now. My spacers are between the crossmember and frame JFYI.
  12. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Yeah they work great until you put even the slightest load on them... a couple months ago I high centered my k5 on the top of a sand mound and those factory spacers bent back the frame rail in two very pronounced areas (where the little spacers were). Now I have 1" square tubing it its place. They will spread the force over a much larger area.
