Dropped & clocked t-case
Discussion in 'The Garage' started by 88K5Jimmy, Jan 9, 2006.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Has anybody on here clocked a tc that has been dropped for driveline vibration issues? My 208 is dropped with the factory 1" spacers and I thought that you could might be able to clock the tcase to a higher setting than if the case was in the stock location and using the clocking ring.
    Also, has anybody solved the issue of running a clocked 208 on a daily driver? Will it adequately be cooled? I *think* I remember seeing a pic of a Ford 208 that came clocked from the factory, so maybe it isn't and issue?
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I would think that a clocked up t-case that is already dropped would cause uber-killer front driveline angles. With the drop you are already pointing the front output up then turn it up more. Your best bet would be to figure out how to lose the drop and put the crossmember back against the frame.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    agreed.
    If you clock the tcase it will put the rear about where it was to begin with.
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    My 241 is dropped an inch and clocked flat. The ONLY way it will fit without body mod's is w/ a 1" body lift. The "factory" front driveshaft will barely come CLOSE to working, and only if it's longer. You're gonna have to clearance the CV and rotate the pinion up on the front end. MINIMUM, and at that, flex will be pretty bad before it's bound back up. Bringing the case back up that 1" would help out a LOT. The new front axle I'm putting in is cut and turned so that helps (then again, the 241 may or may not be going back in...)
    KP
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Of all the posts I've the rear output doesn't move in any direction when clocking it, up, down, left right, anywhere. People have been having problems with front angles which I already knew. I was just wondering if having the tcase clocked would let it rotate up higher than if the tcase was in the stock location, meaning more tcase to floorpan clearance to go higher.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    never heard of or had any issue with a clocked tcase in a DD. i ran mine in my dd for almost a year, took it out when i put a stick in it and couldn't use it.
  7. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    if you dont use the stock cross member, you can push the drivetrain up, but then you must cut a hole in the floor and modify your passenger seat.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The whole concept sounds kinda' counter-productive. The entire idea behind clocking the t-case is to gain ground clearance, so why drop the entire t-case down 1". I understand your point about floor clearance, but I just don't think that is the answer to the problem based on the ultimate goal (gaining ground clearance).
  9. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    So if I'm understanding this right by having the tcase dropped an inch and NOT having a 1" body lift, my tcase would "in theory" only be sticking down approximately an 1" below the frame. I know I could get a better measurement by crawling under the truck and putting a tape on it using the information I was given by DIY4x4. He states his ring in the "mild" position raises the centerline of the front input my 4.5". If memory serves me right the rear centerline portion of the tcase is in direct line with the front centerline output, so in turn if the front centerline output is rotated 4.5" then the rear centerline of the tcase would be rotated 4.5" as well. However, I do not know if there are any floorpan mods with the "mild" setting, waiting on a reply back. I would go measure all this but work and snow are keeping me from it, just tossing it around in my head. Again this is all in "theory."
    Not my intent to cut up the floor on my daily driver...maybe I should have made that more clear.
  10. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    clocking it up w/o a body lift the top of the case will hit the floorboards thats why he has a 1" BL in to clear the clocked t-case.
  11. Kyle89K5
    2,273
    OKLAHOMA
    Here's a side shot of mine, clocked up flat, dropped 1" via the crossmember.
    You pretty much nailed it. With a rear CV shaft, I would have been golden. The crossmember drop was really a little TOO much for my application, but it was a fit that worked for many years.
    KP
  12. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Can you post where the 241 shifter came out?
  13. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    hereis my 241 clocked up before and after. Since the 241 uses a linkage for the shifter all you have to do is adjust to get the full range in the cab.
  14. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Kyle, thanks for the pic. Is that with or w/o the 1" body lift? Just trying to make sure because I feel like I'm confusing everyone. :haha: Also, you don't happen to have a shot of it from the rear with it clocked like that?
  15. Kyle89K5
    2,273
    OKLAHOMA
    sure do bro, but it's at the office. I'll post it up in the morning for ya :)
    That pick is with the 1" BL
