dropped pitman arm vs rasied steering arm
Discussion in 'The Garage' started by blazerpro79, Mar 25, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    which is better for which situations? if i am going to lift up to around 12" what kind of steering solutions should i consider? 79k5/350/350/203
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    12" of lift will need crossover steering or hydro steering.
  3. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    2"-4" drop pitman arm
    6"- up crossover steering
    the raised arm is pretty much useless imho because it causes bump steer on smaller lifts and bigger lifts need crossover. what does the raised arm work on? boat anchor or paper wieght
  4. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    It depends on what axles you have.
    IIRC 1/2 & 3/4 ton you can get 2" pitman arm,4" drop drag link, 4" steering arm. & 3" spacer for 13" lift. I would not recommend that much this stuff.
    On a dana 60 you are limited to 2" pitman arm, 4" drop drag link, & 3" block for 9" total even though I did run it with 12" springs on my old k5.
    On the suburban I have a dana 60 and went with crossover steering because of 12" springs & 1" zero rate pushing the axle forward.
  5. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    i second the crossover and hydro for the big tires. stay away from the stock setup in any form.
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    bolt it to the frame and use it as a giant tow hook.
  7. divorced
    Jul 20, 2004
    5,115
    Would that work? :confused: :thinking: :thinking:
  8. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Every time I see your avatar I die laughing.....
    Sorry about the thread hijack just had to get that out to divorced!
  9. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I have this exact setup that was on my '81 when I bought itand it's not that good at all. It "works" for street use, but on the trail there is pretty poor steering control.
    I'm taking the lift and steering setup out and selling it here in the next month or so, putting 6" instead of 12" springs and going for crossover steering
  10. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    go crossover best thing i ever did
