dropped pitman arm
Discussion in 'The Garage' started by 78Suburban, Nov 27, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    That one goes on a 2wd box, for crossover steering. But, I *think* that you can index it for use with standard steering, you still need a 2wd box to use that arm.
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    who carries an arm that I could bolt right up to stock steering?
    thanks,
    James
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
  5. curtsk5
    curtsk5 Registered Member
    Dec 27, 2004
    11
    Lufkin, Texas
    i have one for sale!
  6. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    any body wanna share how hard it was to install? any special tools/ procedures required? the BFH isn't required is it?
    thanks,
    James
  8. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    If it was my truck I would forget about the pitman arm and use a raised steering arm instead. GM frames are known for cracking around the steering box bolts and a drop pit man would only make that worse as it puts more leverage on the steering box. :doah: The raised steering arm work just as good as the pitman arm and also comes with most kits. Check out Rough Country .com or Offroaddesign.com for more info. ;)
    78 k5/350/465/60/14sf/37''boggers
    85 sub-buggy/350/700/208/10blts welded/35''swampers
  9. mayerichm
    mayerichm Registered Member
    Aug 9, 2005
    15
    Oklahoma
    werd, i bought one off e-bay for 19.99 and 12.00 shipping.
  10. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I have an ORD steering brace, and I don't wanna get into the BFH nightmare it seems so many people fall into with steering arms... from searching, it seems that raised arms tend to overcompensate for a 4" lift.
  11. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Easy install. You will need a pickle fork to separate the drag link, and the BFH migt be required to smack it. Soak the steering box end with penetrating oil, remove the bolt, and then take/tap it off. The install is self explanatory after that.
