Dropped T-Case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by STV, Mar 30, 2001.
  1. STV
    STV Registered Member
    Dec 16, 2000
    25
    Winnipeg, MB Canada
    I just swapped my 4" lift from my 1980 (flipped it) into a 1991 and I had to lengthen my rear drive shaft. I still have minor vibration and was wondering if any of you lower your T-case to help with driveline angle. If so, buy how much. Thanks for your help with the fuel question previously.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes it will help the vibration if you drop the t-case. on all 4 of the crossmember bolts is a 1in spacer just take that of it curent position and position it between the frame and the crossmember and you will have a 1 inch drop
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
