dropping a starter on a th350
Discussion in 'The Garage' started by adamforsythe, Jan 17, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    The last starter I dropped was on a F-250 diesel. Can anyone tell me how to drop the start on a 1985 K5 blazer with a Th350 tranny? where are the bolts that hold it on?
    Adam
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    0. ensure that the starter is bad by troubleshooting
    1. on hook neg terminal on battery
    2.locate starter on passenger side of engine block
    3.Romove 2 bolts that secure starter to block
    4. when starter is away from engine block, remove wires on solenoid
    5.If any shims are present, intall with new starter.
    6. installation is reverse of removal
    7. return old starter to parts store for core
    Total time......30 minutes
    Is this what you wanted??
    Rob
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Where are the bolts located?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    near the nose cone going up into the block. you will see them clearly when you climb under
  5. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    When you look on the bottom of the engine on the passenger side, towards the rear, you will see the 2 bolts as plain as day unless you have lots of dirt, grease, etc hiding them.
    Its really easy, and when you go look at it, you will realize it.
    Rob
  6. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    should only be 2 bolts that bolt the starter to the engine block on the pass side. They are easily seen from underneath right at the back of the motor just before the tranny
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The 2 bolts are the easy part, getting all the wires off the front of the starter solinoid can be the bitch about the whole job. It isn't that hard to do though. Drop it out and have the parts store check it for you.
    Harley
