Dropping a Steering Column
Discussion in 'The Garage' started by Hossbaby50, Aug 2, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need to know how to drop a steering column. I need to get to the wiring that sits above the steering column near the fuse panel. (the ignition switch wires)
    Do I just remove the 2 nuts near where the column meets the dash? I don't need to remove the column just drop it down to possibly get some clearence to work in there.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You will possibly also need to remove all the screws at the attaching plate to the firewall, (8) IIRC.
  3. the fall guy
    the fall guy Registered Member
    Jul 1, 2004
    35
    On my 85 i removed theto bolts underneath the column, remove the cover for the gauges, and disconnect your wire for the transmission indicatror if you have a auto.I did mine without removing the screws for the firewall but whatever works for you. /forums/images/graemlins/k5.gif
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    you need to unhook the steering shaft someplace, take off the plate at the firewall, unhook the wiring and take off the 2 dash bolts and she should be good...
