Dropping a T-case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OLDSTEEL, Sep 23, 2002.
  1. OLDSTEEL
    OLDSTEEL 1/2 ton status
    Mar 11, 2000
    107
    SANDIEGO CA
    I'm getting ready to drop my T-case and tranny to change out the torque converter. Last time I did this I almost ate an NP203. Dose anyone have any suggestions on how to make this process easier.
  2. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    I use a floor jack and drop it all together
    then i break it down
    much easier for 1 guy,
    then i mount the trans
    and then put the tcase on the jack and bolt it up
    works for me and ive pulled the same one 6 times
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Rent or buy a transmission jack. You can chain the t-case/tranny to the stand so it won't fall.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I used a tranny jack and chained the tranny and t-case to it. I didn't even drop the unit down when i changed my flexplate, just slid it back far enough to get it out of the way to do what i had too.
  5. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Pull the seats and pull the floor hatch over the tranny/t-case combo and drop a chain from an engine hoist through there. You can use this to lower them down.
  6. Grim-Reaper
    7,385
    Atlanta
    I have as yet to see a tranny jack that will work worth a flip on a 203. Make your own out of some 3/4 ply and some scraps of 2x4.
  7. OLDSTEEL
    Mar 11, 2000
    107
    SANDIEGO CA
    Thank's I think I'll attempt to build a support from plywood.
  8. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I have an transmission jack attachment that goes on my floor jack. Pulling the NP203 was easy but putting it back in is a pain in the @$$. I dropped it once from about 10 inches up, but it didn't do any damage. Something like Grim made would be great. Wish I was smart enough to think of that /forums/images/icons/crazy.gif
