dropping front spring hangers?
Discussion in 'The Garage' started by MudFlap, Feb 17, 2003.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    Is their anything wrong with making new ones or dropping the front spring hangers on the front springs?
    I have 6" springs and I figured that this would be a good way to get some extra lift and help my pinion angle.
  2. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    No experience, but watch your caster angle if you do much... might want shims or do some custom rotation.
    I have wondered about building some nice ones, not too much lower than stock, but with some nice gussets (sp?) out of some heavy stock instead of the stamped stock jobbers (sure do get cluttered in that region /forums/images/graemlins/wink.gif)
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    There was a guy around here who had cut of the forward spring hangers and welded in like a 4"x4" square tube and then put the mounts back on the bottom of it. It looked cheesy and he ended up with front driveline problems. He ended up taking it back out and getting taller springs. Ended up with the same lift but no driveline problems.
  4. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I'am doing that to my truck right now. /forums/images/graemlins/thumb.gif
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  6. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    /forums/images/graemlins/ignore.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/ignore.gif
  7. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/ignore.gif
  8. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Can anyone say Caster Disaster! This is NOT a good idea.
    If you drop BOTH ends youll retain the caster that you need.
    OR if ya wanna go high$$ you can have the axle tubes cut and turned to regain the ness. caster after the work is done.
  9. bigbluek20
    Dec 18, 2001
    119
    Loveland, Colorado
    Yikes... stuff like that is the reason we end up fighting lift laws /forums/images/graemlins/ignore.gif
  10. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    I believe that I can cut my axle tubes and reweld them, my dad owns a machining and weld shop.
    So if I want to get 8" of lift with 6" springs, should I put on a longer shackle, drop the front hangers, use zero rates or some kind of combination of the three? Or is there anything else that I can do?
    Trey
  11. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    [/ QUOTE ] Its not quite as easy as just cutting them off and rewelding. Your dad has a machine shop so you have a definate plus. The tubes and ends MUST be true and at the same angle. Any deviation from the tubes being true would give the same effect as a bent housing, IF you got the shafts in they would wear badly and most likely break easier w/ a bow in them. And be sure to get the caster back where it belongs or it will pull and drift and change lanes on things as small as the painted stripes on the road.
    I rotated the pinion up 1/2in when I did the spring over on my Jeep and it would drift all over and the painted lines on the road were almost a religious experience. /forums/images/graemlins/eek.gif I shimmed the pinion back down and it handled fine after that.
    Im not saying your dads shop cant do it, just giving you a heads up on what to watch out for incase you dont know. /forums/images/graemlins/thumb.gif
  12. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks for the heads up, but I wan't just gonna cut them with a saw and twist them and reweld them. I understand that everything needs to be true and my dad and I will do it right, and get everything where it needs to be if I decide to do turn the tubes.
    Trey
  13. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Thanks for the heads up, but I wan't just gonna cut them with a saw and twist them and reweld them. I understand that everything needs to be true and my dad and I will do it right, and get everything where it needs to be if I decide to do turn the tubes.Thanks
    Trey
    a lot of jeep guys do this they grind the weld off the knuckles and beat them off the axle tubes. put em back on where they want em and weld em up again. i know there is more to it than that, but that's the basics of it. if you just shim the pinion up it screws up your castor and you will have horrible bumpsteer like the other guy said. i had a 6 inch lifted blazer that i shimmed the front on and it would change lanes as well with a little bump or on a panic stop. very scary - for me and the other motorists! /forums/images/graemlins/shocked.gif
