dropping my transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater74, Jul 26, 2001.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    I'm fixen to order my 4" lift (shakle flip)from ORD and i understand everything that is involved in doing this except dropping the transfer case how is this done and how far do I have to drop it? hopefully the wife will let me use our tax reimbursement check to do this
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Just place a jack under the skid pan on the transfer case, then look for the 2 bolts on each side of the t-case crossmember. You will see that there will be 2 barrel looking spacers above the nuts. You simply remove the nuts, then lower the jack just enuff to get the spacers in betwen the frame and the crossmember, then re-insert the bolt and nut and tighten. Then do this to the other side.
    Did you say I have monkeys flying outta my butt?[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I did it by myself in about 20 minutes. It is really easy.............Dan
    If it ain't broke.......Don't fix it....
  4. beater74
    May 29, 2001
    1,749
    atlanta
    so i use those barrel looking spacers that are above the nut to place in between the member and the frame or what do you use to do this?
  5. Grim-Reaper
    7,385
    Atlanta
    You don't need to drop it in a 74. If your still full time you better not drop it because it will bind the CV joint.
    What you will have to do it cut off the purches and rotate the pinion down 5 deg on the rear axle. That's what I did on my 75 and it runs down the road vibration free all the way to 70mph. The people running into the vibe problem all seem to be 10 bolt 208 or 241 case. Not sure if the 12 bolt's pinion sits higher our it's that slip yoke drive shaft but I didn't run into any problems the newer trucks are having.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    Grim-Reaper
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Mine never had a vibration until I blew the slip yoke - Now it's got an extreme vibe to it, that comes in around 55 and goes away at 65. I'd guess that the problem lies with the slip yoke shaft - 29.5" long means that it worked at some pretty tight angles before lifting the rig.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Dah, I need to start paying more attention to the posts. My bad. I forgot about the shackle flip, as this sends your rear pinion angle way up above center line from the T-case.
    Looks like you need to get to cutting and welding bro.
    Thanks for cleanin up after us Grimmy. You outta be getting pretty good at that by now, with little Zan![​IMG]
