dropping t-case, driveline degree change (how much)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, May 31, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    My specs:
    6" front springs
    echobit flip in the rear
    36" tires
    I haven't lifted the rear yet and am expecting some pretty severe driveline angles. Is there an expected amount of degree change that would result from dropping the t-case? I would like to be able to stay with a regular driveshaft (all u-joint). Would this be possible?
  2. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    Put the lift on, drive it, then decide if you need to drop the case. W/ 5.5" of lift on my '80 I needed to drop the case about 1" w/ 5.5" of lift on my '73 I didn't. The difference: two different x-fer cases.
  3. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    I'm using that same setup with the addition of a 1 in zero rate in the back. The flip pointed my pinion straight at the t-case, so I'm having to get a CV shaft for the rear.
