Dropping t-case problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88k5canuck, Nov 28, 2001.
  1. 88k5canuck
    88k5canuck Registered Member
    Mar 1, 2001
    26
    Ontario, Canada
    Well he is the short of it. I added a 4" superlift springs about 10 months ago. Then recently I added 1.5" blocks in the rear to level the truck out. After this, there is a noise coming from the back of the transfer case when I let off the gas. The 4x4 shop said just lower the transfer case. My truck is a 88 so it has the spacer under the cross member. I was just going to put the spacers above the the cross memer. My problem is the front y-pipe of the exhaust is almost hitting the front driveshaft already. If I move it anymore I will be in trouble.
    Does this mean I have to convert to dual exhaust with dual converts too. I am under emission laws. This is pretty costly fix for dropping the t-case.
    Thanks for your reponse ahead of time.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I know someone on this site said something about getting a replacement pipe or getting the Y pipe fixed or a new one made for cheaper than converting to duals.
    I have never had to do anything because lucky for me, I never had the Y pipe on anything.
    I have seen them while working on others trucks. It does appear after a lift has been installed that you may be able to run the Y pipe OVER the driveshaft, but IMO, that may come close to the tranny pan and generate heat to the transmission. Another option would be to have a new longer Y pipe made to fit down lower below the driveshaft. But these are just my ideas for the cheap route. [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Wes is right. The more cost effective route is to simply get a shop to re-route your y-pipe to a better location.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    This vibration could be bad U-joints, too. Do yourself a favor and spend $7 on one of those little angle finder gauges and figure out what your T-case output shaft and rear-end pinion angles are. Then you be able to figure out what is wrong and what needs to be done without a lot of guessing.
    Lowering the transfer case is easy and quick and could possibly solve your problem, so it's worth a try. But if that doesn't make everything good, where will you go from there?
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Also remember your exhaust will come down a little with the t case drop because you are also tilting the engine at the same time. I had a new pipe made to clear mine and it was only $42 but the t case drop had nothing to do with getting the new pipe bent because mine did not clear after the lift and axle swap even before dropping the case.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
