dropping t-case with a CV shaft?
Discussion in 'The Garage' started by MudFlap, Apr 13, 2003.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    Do I need to drop my t-case if I am gonna be putting in a rear CV driveshaft?
    Trey
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    dropping t-case is more for the front angle
  3. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    How is that?
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The front angle is a lot steeper than the rear.
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I think he means drop as in remove the T-case. Right?
  6. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Sorry I was not very clear on that.
    I meant to say do you need to lower the t-case if you are using a cv rear driveshaft?
    TRey
  7. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    most times no you wont need to drop the t-case if using a CV rear driveshaft. just want to make sure you have your pinion pointed a couple degrees down from the t-case and take good measurements for driveshaft length.
  8. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks.
    Trey
  9. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Mine has a cv and i havent lowered the t case. Now im confused, why would you point the pinion down?
  10. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    How is lowering the case (assuming a married case) going to help the front when it makes the angle at the front shaft steeper?
  11. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    It depends on how much lift you have. Give us some info & we can help. Generally slip yokes need to be opperated at less angle than fixed. The best answer is to drive it and see if you need it. No reason to give back clerance you just put on.
  12. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Make pinion point down a degree or so to makeup for axlewrap--so i hear.
    Lowering Tcase actaully makes front driveline at a worse angle but its ok, cause the front shaft is a constant velocity (cv) from the factory.
    You may or may not have to drop tcase, depending on how much lift you are getting and how long of a driveshaft? I have about 7" of lift and i have the tcase dropped a bit and a cv shaft and i have absolutely no driveline vibe/noise.
