Dropping Tranny Pan In Driveway
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Jun 4, 2001.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I want to drop my tranny pan to put in a temp gauge. Any tips on dropping the thing while it is in my driveway without making a HUGE mess? Thanks!
    Dawson
    Raleigh, NC
    88 K5, 4" lift, 33" BFG muds
  2. johnnysjimmy
    johnnysjimmy Registered Member
    Apr 23, 2001
    47
    be very careful lol
    73' GMC Jimmy 8" lift and 35" tires.....14 boltff and big 10 bolt on the way
  3. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    Yeah, I got a fluid transfer pump from the parts store for about $15 bucks. It has a long extension so theoretically you can change your oil without removing the drain plug. However, it works good for removing a few quarts from your tranny and making less of a mess on the driveway. I can't remember the name but it used to be orange in color.
    90 GMC Jimmy, 350 TBI, 700R4, 32's
    84 Bronco II 204,000 miles and counting...........that's 206,000 and counting now
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    The way i do it is to pull most of the bolts out and leave the ones in the "corners".Then remove those slowly,EXCEPT FOR 1 BOLT!!! and the fluid should begin to drain out.Slowly loosen them until they come out,progressivly(sp) draining the fluid out. When the others are out pull on the pan a little to drain some more from the pan while its hanging by the 1 corner. Finally pull the last bolt,and remove the pan. There will still be fluid in the pan but if your careful you wont get a tranny fluid bath. I hope this helps,if ive confused ya ill try to clear it up.[​IMG]
    PURE INSANITY
    86 blazer see it at:<A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292792569>http://www.zing.com/album/pictures.html?id=4292792569</A>
  5. ericsoffroad
    ericsoffroad Registered Member
    May 29, 2001
    27
    wa vancouver
    get a big a@@ pan and watch out i also recomend not draining it when it is warm as we all know atf expands when it get hot so cool is better
  6. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I agree with pureinsanity, just loosen the bolt a little then loosen one half of the pan mor and let the fluid drain out into a large catch pan, i also recomend putting down newspaper or cardboard to catch any the pan may miss, and why not do it in the street?
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  7. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK i left out the pan! DUH! [​IMG]
    PURE INSANITY
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Get a BIG drain pan and if you can ,set it on top of something like a wheel or cement blocks or something.The closer you can get the pan to the tranny the less splash yer gonna have.If its windy youre gonna need to block the wind because that just blows ATF all over.Then take out all the bolts but one.Wack the side of the pan with a rubber mallet ,not hard enough to bend up the pan,just hard enough to break the seal of the gasket.Now is when the mess starts after the pan has broken loose.Wait for what ever is gonna run out to run out and then support the pan with one hand and take out the last bolt with the other.Slowly pull it down and dump it in the drain pan.If you change the filter make sure that the old gasket or O ring on it comes off with it.Putting the new one on top of the old one and doubling them up can cause funky problems.And last ,make sure the pan is flat around the holes before you put it back on and dont overtorque the pan bolts.I torque pretty much all trans pan bolts to between 85-100 in/lbs.Good luck
    All work and no beer makes Frizz a dull boy
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'v used the fluid transfer pump like Matman says. It works very well. Saves a big mess. Mine is orange and came with enough hose to slide down the dipstik hole and pump out the fluid. It is a hand operated pump. it cost about 14.00. It is also handy for changing the diff fluids also.
    I also put a drain plug kit in my trans pan the last time I had it off. It is the best $5.00 bill I've ever put in my truck. Makes changing the trans fluid a piece of cake. Most auto parts stores sell them.
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    When I did mine, I put a big sheet of plywood I didn't care about on the ground and laid on it...face it, there is almost no way to not get ATF on the driveway, every time I try my best, but......I think I'm going to do all my oil changes in the street from now on.
    90K5
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i just have a big bucket. bigger round than the pan. used bottom half of a trash can. the next pan i put on i had a drain plug in... HINT HINT.....
    they sell drain plug kits for real cheap out here. 8 smackers....
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  12. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Drill a 1/2" Hole in the pan and drain into a bucket - Then put a drain plug kit in when you're done. Also get a bag of mortar - It will pick up any spills without leaving any trace behind.
    I'm so poor I can't even pay attention [​IMG]
  13. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    Great call.
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Uh...I just remove the drain plug! Oh sorry you don't have one;(
    '71 Blazer CST with alot of rust
