Dropping Transfer Case
Discussion in 'The Garage' started by blazintweety, Jul 24, 2003.
  1. blazintweety
    blazintweety Registered Member
    Jul 21, 2003
    6
    I'm gonna be dropping my transfer case and tranny tomorrow morning and need to know how to pop the drive shafts off the transfer case. It's a np208.
    Also, can anyone tell me if it's synchronized or non-synchronized? I know we'll know once we open it up, but it'd be nice to know beforehand.
  2. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    I dont have a 208 but I am pretty sure the following info is good.
    With a 208 the rear drive shaft is connected to the transfer case via a slip yoke. This means once you disconnect the drive shaft from the rear axle just pull the drive shaft and slip yoke out of the transfer case, it should just come right out.
    synchronized or non-synchronized? I dont know what you are referring to!
    Hope this helps a little, /forums/images/graemlins/thumb.gif
  3. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    it just slides out
  4. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Are you asking if the shafts need to be reinstalled in the sam pos they cam out? That answer is no. As far as the case being synchronized, High range is-ie, shift on the fly, Low range is not, and since there is no clutch that's why you need to be stopped, or be some kind of incrediable gear shifter to engage the low range planetaries.
  5. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Just a side note, when you drop a rear driveshaft, make sure you remember the vehicle can roll unless you have taken precautions or are on flat ground.
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    three ratchet straps, two trailer ramps and a brick.
    that's how i dropped mine.
  7. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    Also, be prepared to catch the oil coming out when the shaft is removed.
