DRP occured?
Discussion in 'The Garage' started by southernspeed, Sep 4, 2005.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Can someone explain what this is in the WINaldl programme? Thanks.
  2. dyeager535
    26,982
    191
    Distributor Reference Pulse unless I'm mistaken.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    The DRP Occured flag comes on almost as regularly as the lean/rich flag (every few seconds). I know the lean flag should be doing that but a distributor reference pulse surely should be very regular or not at all shouldn't it?
  4. dyeager535
    26,982
    191
    I just went over to thirdgen to check it out, sounds like that flag doesn't really indicate anything critical if the engine is running ok.
    I don't know about regularity though.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    OK thanks. I'll have to look into it a bit more just to satisfy my own curiosity! I'll run the programme on my '78 too ('90 motor in it) and see if I get the same result. Thanks.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I see the exact same thing on mine, since day 1. I would say it's normal. If I was to guess, the reason it shows up on the screen, is the ECM is polling the DRP input to make sure it's there.
