Drum brake rebuild write-up
Discussion in 'The Garage' started by Robert D, Oct 20, 2005.
  1. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    Is there a good/decent writeup on rebuilding the rear drum brakes on a '91 Jimmy Fullsize? I did some searching but came up with mostly posts regarding specific problems people have with the drums. The brakes on my truck are beginning to squeak pretty badly when trying to hold the truck while creeping in stop-traffic (yes I have an auto).
  2. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    I did a google search and found this from Hot Rod magazine. It says their rebuild is for GM drums too - should be pretty helpful
    http://www.hotrod.com/howto/43118/
    Do some more searching and I'm sure you'll find a very detailed writeup.
    Good luck :o
  3. Robert D
    Oct 2, 2005
    261
    Austin, TX
    Thanks, after reading through that tutorial it does not seem like too much trouble to rebuild drum brakes. I may do it at the same time I flush the brake fluid.
