Drum brake spring trick?
Discussion in 'The Garage' started by rampage, May 23, 2002.
  1. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Besides fighting with the springs and cussing the whole time, what trick do you use to take the springs off and put them back on your drum brakes?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Go to Sears and buy a pair of brake spring pliers. You'll be glad you did. Makes removing and installing those springs easy! /forums/images/icons/cool.gif
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    This is one of those tasks that the proper tools make simple.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't like the tool that looks like a big pair of pliers with a pointy end and a hooked end. The tools I like are the ones that look like a screwdriver with a cup shaped thing on the end, and a tool that looks like a screwdriver or rod with two ends (one end like a really narrow spoon and the other with a small cup with a tab on it).
  5. rampage
    Mar 20, 2001
    2,260
    72
    I never knew there was a tool for this. Got one last night and what a difference it made /forums/images/icons/smile.gif
    Thanks /forums/images/icons/cool.gif
  6. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i just use speaker wire and some duckbill plyers.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    There's a tool for everything! /forums/images/icons/wink.gif The trick is knowing which ones you need and which ones you don't. /forums/images/icons/cool.gif
  8. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I use long zip ties throught the pad locating pins to hold the pads firmly in place while I put all the springs and such on and it made the job much quicker.
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Can you ever have too many tools? ar, ar, ar!! /forums/images/icons/smile.gif
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I used to wonder about that too. Then I saw a Kent-Moore tool catalog. /forums/images/icons/shocked.gif They make all of the GM factory service tools. You know, all the little J-xxxx gadgets that they show in the factory service manuals. I'd have to have another garage just to keep 'em all in. /forums/images/icons/wink.gif But a lot of them aren't really required unless you fix vehicles for a living. I can install a wheel seal just fine without a $50 seal installation tool. It probably takes me 10 seconds longer, but then I don't have to see how many cars I get get through a bay every day. /forums/images/icons/cool.gif
  11. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Wheel seal tools make it easy. A friend of mine is the head mech for a large fleet of big rigs. Their seal supplier gives him the seal drivers for free. He gave me his old one and the plates for the seals on my big rig.
