drum brake sticking around turns
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Apr 2, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    how can i loosen it up, keep it from grabbin?
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    are the bearings ok?
  3. tecton
    Dec 1, 2002
    1,553
    WV
    it doesnt do it going straight
    so i would assume so?
    if it was bearings it would do it all the time wouldnt it?
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    You have something shifting when yoou go around corners, this is not good, you need to jack up the entire rear end and check out everything. movement brakes, axles, everything.
    I broke the housing a few years ago on my 10 bolt and it didn't really make the brakes stick, but things were getting real loose. It's not good.
    Check it out before anything bad or any worse damage if any occurs.
  5. tecton
    Dec 1, 2002
    1,553
    WV
    i took it back to the garage
    rear end was fine
    they said something about some clutch on the brake was sticking
    but it was definately not the rear end...they pryed it loose and were turning the wheels freely, then whenever i hit the brakes the first time it happend again
  6. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Then remove the drum and spray brake cleaner all over everything, see if you can see any parts that have obvious damage, make sure there is no oil on the shoes.
    Mine sticks real bad when it gets wet with water, i need to tear mine apart as well.
    But there is definately something not right within that assembly. Best i can say is just check it out. /forums/images/graemlins/dunno.gif
