drum brakes
Discussion in 'The Garage' started by tecton, Apr 17, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    i have one sticking
    any tips or diagrams for taking it apart to see what the deal is?
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    my truck seems to do this if it sits for a few days or more, just stopping , putting it in reverse and stopping a couple times and it seems to go away, or after driving it a little, not sure why it does it never botherd to try, but theres not much to them, just take the drum of and look simple as that, maybe a spring came loose or broke, w/e..might need a couple special tools like a spring tool or whatnot
  3. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    The parking brake cable could be sticking, or could be (as you said) be a broken brake shoe return spring. It might be that the backing plates have grooves wore into the backing plate pads that the shoes rest against. You will not know until you get it apart.
  4. tecton
    Dec 1, 2002
    1,553
    WV
    around turns it grabs and shakes the truck
    i tried backing up and stopping, it did it again right after i pulled off from doing that
    ill get her apart tomorrow and check for sure
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea, when my truck does this it shakes the whole truck somethin wicked , and pulls to the side real hard, maybe its a front caliper come to think of it .. /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what year truck ? after 70 ? or before 70 ? front or rear ?
    if a drum is grabbing bad and maybe evne locking up then it might bne fluid soaked into brake shoes material, leaking wheel cylinder or axle seal
    if its a front drum doing it then its probably cuz the both fronts are not adjusted out to close enough to the same so that one is braking before the other, and that is what would cause a bad pull to one side when braking
    its pretty straightforward ot take apart drum brakes, you just need pliers to take apart rears,
    if are fronts then you need tools to unbolt the hubs that the drums ride on
    most of the time you have ot back off the shoes so that the drum will evne slid eoff the shoes, this is the real fun part, and alot of the times none of the adjustment access knockouts are knocked out and open, so you have to find them, sometimes they are on the face of the drum and sometimes they are just in the backplate, or both.
