drum brakes
Discussion in 'The Garage' started by tecton, May 1, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    my driver side rear drum is grabbing around turns
    if something like this was wrong with the brake, would it probably be one of those springs is loose/tight/worn or something like that?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    When mine did that, i had a busted axle tube, wher it's pressed in the housing, actually was more like the housing broke at the flange that holds the tube. As far as i know, if if any parts in the drum assembly are broke, it should rub all the time, i would seriously go over the whole thing and throughly check it out, have any oil leakage of anything lightly coated with gear oil back there?
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Is it grabbing when the brakes are applied or any time you are turning?
    It may be a leaking wheel seal. Oil on the shoes makes them do strange things.
  4. tecton
    Dec 1, 2002
    1,553
    WV
    just when im turning
    i thought it was the rear end, but i dont lose any power, doesnt feel like a slipping
    also, if i hit the gas is grabs like a mofo, but if i just roll, it feels like that brake is lightly applied slowing me down around the turn
    and finally, the truck wants to pull to the passenger side slightly
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Got a Gov-Loc in that thing?
  6. tecton
    Dec 1, 2002
    1,553
    WV
    eaton posi
    and i just put in some posi additive, and ive checked it, its no metal, no signs of damage
