Drum from hub removal question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazbrnc, Aug 21, 2001.
  1. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    I'm in the middle of a disc swap on a 14 bolt ff. Is it possible to seperate the drum from the hub by myself? The local brake shop wants $40 per side and I am cheap.
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    $40 each!?!?!?!? Holy crap! All you do is press out the studs and the 2 fall apart from each other. If you don't have a press, sacrifice a lug nut by screwing it part way onto each stud, then pounding on the nut to drive the stud out. This way you won't mess up the threads on the studs. [​IMG] Feel free to send me the $80 you'll save. [​IMG] [​IMG]
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Also give the studs a dose of PB Blaster/Zep/Liquid Wrench/Penetrant of your choice a little bit beforehand - makes the job much easier.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    PB blaster for sure and the lugs will set you up. Man my shop only charged $4 for both sides to swap out the rotors. $80??? Man I need to get into that line of work!!![​IMG]
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  5. blazbrnc
    Mar 16, 2001
    181
    southern MI
    And that was the cheapest quote I got. Michigan roads like to cause any steel parts that are bolted or pressed together become one. But you gotta love that orange tint. I soaked them last night with some PB so with a little persuading they should fall right apart, right?
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    The old hammer down phrase will bring you home. You may have to cuss it just a bit![​IMG]
  7. blazbrnc
    Mar 16, 2001
    181
    southern MI
    Thanks for the help, sounds like I better put some earplugs in for this.
  8. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I have done this twice in two weeks...Easiest thing i have ever done...
    Surfing is Life...
